Instrument cluster
unofon
Hi All
My Auris has developed a fault in the instrument cluster all the lights are flashing like a christmas tree when ignition is turned off
I did disconnect the Battery and it cured it but fault has reappeared
Any advice?
Unofon
Sounds like you have a faulty circuit board or wiring problem. Auto electrician needed.
What Engine ?
I suspected so, There is a Technical Service Bulletin from Toyota reference:
BE-0070T-0514
DESCRIPTION OF PHENOMENON
Some customers may experience and report that the lights of their combination meter start to flash after the ignition is switched to OFF.
PRODUCTION CHANGE
The ECO RUN Converter assy* has been improved.
This issue only affects 1.33 engined Auris, Verso-s, Yaris & Urban Criuser with stop start system.
