tyre jell
ffej
hi anyone got an apian on tyre jells or spray dressings ,does it make them crack ??
Extract from the 2015 Auto Express report on tyre shine -
Wheels are key to a car’s appearance, but the even coolest alloys will look tame if they’re wrapped in a grey, grimy tyre. The solution is a tyre shine, which can restore that ‘as new’ look to the sidewall of even the most tired rubber. It’s not all for show, either, as regular treatment with a tyre shine keeps rubber supple and slows the damaging effects of ultra-violet light that can cause cracking and premature failure. Applying a tyre shine is usually quick and easy, plus most won’t break the bank.
See: http://www.autoexpress.co.uk/accessories-tyres/90998/best-tyre-shine-2015
+1 for the AutoGlym dressing but if in a hurry a can of CarPlan instant tyre shine foam is fine. It doesn't last as long but you  spray it on and walk away - it's does it's thing then safely dissolves away leaving a decent finish.
