Fogs...
thom1983
Evening all...is it possible to retro fit front fog lights?
Sent from my iPhone using Tapatalk
Since none of the Mk2 owners have not answered, and I am not sure myself, I will mention the Mk1 fog light upgrade. It may be the same for the Mk2.
I used to own a Mk1 GLS model which had the front fog lights as standard.
The wiring was in place, so the only modification needed is the stalk with the front fog position, the lights themselves, and I think the relay in the drivers foot well near the fusebox. Check the instrument panel to make sure the front fog indicator has a bulb fitted.
Once they are all connected everything should work!
Hopefully somebody will answer the question but, it seems most people either own the higher spec cars or have not bothered.
