attempted to change brake pads
frankie406
Tried to change pads on 2010 1.33vvti auris after waiting on the wind back tool and the weather I finally got down to it.started at rear pads 1st.wind back is a terrible idea for a start.so I push the piston back took out old pads cleaned up the shims and the dirt and rust all around it.i greased up nuts bolts and clips for future work.i offered the pads up and!!! They were the wrong pads😠😠euro car parts has struck yet again! This has happened a few times last was the fuel filter on the avensis and the brake discs on it too! Cannot get an answer from them on any of these matters!so if you guys are buying from them check and double check that it's right!😠😠😠
