Yaris electrical fault
tony65
Greetings, I have a problem with my 08 D4d yaris and I was wondering if anyone else has had this one. When It has rained the car turns over once then then the keyless push button indicator  turns red, the first time it happened it took 45 min before it would start, Battery checked out as only having 9 volts and discharging so I have replaced that, starter motor has been out and bench tested ok. After the third time  I took the car to my toyota dealer who have been trying to diagnose the fault for the last week,  the fact that it only occurs after/during a rainy spell indicates a water ingress / electrical fault. Has anyone else had this happen and are there any usual areas where leaks occur, I know it is like looking for a needle in a haystack..... any ideas ?
