Hi all,
For a while now my airco stinks, I think it could be some mold.
So I bought myself a Airco cleaner, for about 10 euros. In the manual I have to insert the adapter into the air inlet of the air conditioning and completely empty the can.
I don't have much knowledge about cars, I tried youtube and google. But where is the air inlet of the airconditioning of the Aygo?
regards,
DennyInsert other media
Pretty good instructions here; http://steampunkworkshop.com/fixing-musty-smell-my-2007-toyota-yaris/
If you follow the instructions to remove the cabin filter that's where you can discharge your Airco cleaner into. The other item about cleaning out the drain is important too.
when i have used the airbombs in the past it has always mentioned to push the passenger seat forward
have all the vents open and set to windscreen with recirculate turned on ,fan speed on high & engine running
then start the airbomb get out of car and wait until the can stops spraying out.
