What Do These Do?
breezer
Bass is largely non directional... so I don't think it relies too heavily on those little cones to 'direct' the sound
it's more likely to release the pressure created within the sub and 'tunnel' it if you see what I mean...
This is the reason, it allows the box to breath remember the speaker cone travels in two directions, if the box was sealed the output would be a bit limited.
Save money and go to the local plumb centre, use black paint B)
I like the way that the outer diameter is 8cm and the Inner Diameter is 3 inches.
It's probably just under half a cubit tall and weighs 7 hamsters. :blink:
Rich
yeah i had one in my RF 15. Just lets the air out
Like said above, bass is non-directional, u cant really force it to a direction. Like with a 5.1 home cinema system. You can put the sub anyway (mine is behind a sofa) and u cant tell where the bass is coming from, it just fills the room
:thumbsup:
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
