Where the heck is the post cat 02 sensor connection point
Keneboy
Toyota AVENSIS Saloon (T25) 1.6 VVT-i.. Hi need to repalce as its gone , where is the connection point  .. its the 1.6 T25 Avensis , Facelift model
If you dig in the drivers footwell and pull up the footrest (just clips in) peel back the carpet you should see a grommet. Follow the lead to the connector
Hope that helps
