white smoke
tinners4
hi
I have a 1.4 diesel yaris on initially starting the car there is some white smoke comes out the exhaust for a couple of seconds maybe is this something I need to be worried about? it is due for its service in 3 weeks at Toyota if as ive heard there prone to head gasket problems is this something that would be picked up during the servicing?
thank you for any help
Normal id say , its just condensation within the exhaust that is getting exhausted out :) Usually happens when the car is started from cold. Usually should go within a few minutes.
Err.. it could be steam from a small head gasket leak.
Have you checked coolant levels? Are the falling? Is the coolant discoloured?  If Yes and yes, you need to get a sniff test of the coolant to detect exhaust gasses.
Has your coolant antifreeze been changed? Its life is 10 years.
White smoke usually means they have elected another Pope! ;) :)
