Brakes
Orta
In desperate need of some brakes at all four corners. Needing pads and discs.
Found 130656737768 on the 'bay, seem a bargain. Can the performance be expected to be on a par with OEM articles?
But also ran into http://www.eurocarparts.com/ecp/c/Toyota_Avensis_2.0_2005/p/car-parts/brake-friction/brakes/brake-disc/?104820849&1&b2444323b702c604b64a78c966579e12bb4c869b&000027 works out much more expensive of course...
What's the groups opinion?
Unless anyone else has alternatives?
I'd stick with going down to Euro car parts or an equivalent motor factors; the parts will be OEM spec for certain, no waiting for delivery and if the parts are wrong for whatever reason, you can return them and get the right ones in the same day.
What Dan said.  Brakes aren't an area to be saving money on and the euro car parts um parts will pop straight on without any fussing about (used them myself).
Got mine from eBay and came with ebc pads for my t sport, fitting was perfect and work great...
Sent from my HTC One M9 using Tapatalk
I read somewhere that Mintex brakes were good. So I bought a set of pads and fitted them. They seem to work better if worked a lot than the normal set that were on there.
 The wear seems to be very good too.
