Increasingly smokey emissions
Rodigo
Hi all    Just wondering if anyone has same problem with 2.2 d cat t4 car is running well but occasionally / mostly when hot it lets go with a cloud of smoke from the rear that is becoming quite embarrassing  any suggestions plz
My 2001 D4D does this too. Given the recent news about how wildly wrong the official emissions figures are, I would be worried that you are seriously harming people around you using your car. I've switched to a hybrid, the Avensis is now only for occasional use when I need a big boot. Even then I feel guilty starting the thing up! Tesla is on order!!!
Thanks for reply   Thinking if I can't get any improvement or solution without going to main dealer    55 miles away   I might think about a tesla myself.      Cheers
How often do you get this cloud of smoke - is it about every 300 to 500 miles? If so it could be a DPF regen going on whereby it blows all the accumulated crud out of the DPF filter right into the face of traffic following behind you.
Otherwise if it's a fairly regular thing, what's your mileage and how about the car's servicing (air filter, oil changes etc) - has that been done within living memory?
I had the same problem on my RAV4 2.2 D4D. It is a 11 plate and the problem was intermittent excessive smoke. I took it to the local dealer and they remapped the ECU as they said that there was a technical bulletin for the occasional smoke.
This has now cleared the problem. This was done under warranty
Try a lovely quick fix costs next to nothing Blank off the EGR valve, it sounds like it's when the EGR valve kicks in, you have loads of un-burnt fuel etc. going into the exhaust, the EGR valve sends burnt/used exhaust gases into the inlet it's to make the engine run worse to stop it producing NOX. Most people think the EGR valve improves running it doesn't, I have heard all the reasons for not doing it before so please don't give me grief.... but I would rather send a bit of NOX down the exhaust than soot and particles etc. If it work and you stop producing black smoke it must be better for your inlet system, I have seen sootted up inlet manifolds and thick coated EGR valves all caused by recirculating used gases full of soot....
