07 RAV4 t180 White smoke
Mikester199
Hi all
I'm not sure if any of you guys seen my last post on here but I'm suffering from this white smoke problem on my RAV4 and it's driving me crazy!!! Ive had the dpf checked by a professional and he assures me it's not blocked as all the pressures are correct I was advised to take it to me t and have it checked for the ecu re flash for the white smoke problem which they told me it was up to date the technician told me that it could be the 5 th injector and or the egr valve I have now today replaced the 5 th injector with a brand new Toyota part and while I was under the bonnet I also cleaned the egr and blanked it off no lights (I disconnected the Battery for 30+ mins ) went out in it albeit only for a couple of miles and the !Removed! smoke started again !!!!
Does anyone one think that I should run it for a bit longer for the ecu to settle down and learn new values of the 5 th injector or should of I of not blanked the egr at the same time ? Any information will be greatly appreciated as I've done everything now I can think
thanks in advance
mike
have you checked your coolant to rule out head gasket failure?
Hi there
yes done all them checks and all seems fine !!!!
mike
  • 5 months later...
On 27/04/2016 at 8:59 PM, Mikester199 said:
Hi all
I'm not sure if any of you guys seen my last post on here but I'm suffering from this white smoke problem on my RAV4 and it's driving me crazy!!! Ive had the dpf checked by a professional and he assures me it's not blocked as all the pressures are correct I was advised to take it to me t and have it checked for the ecu re flash for the white smoke problem which they told me it was up to date the technician told me that it could be the 5 th injector and or the egr valve I have now today replaced the 5 th injector with a brand new Toyota part and while I was under the bonnet I also cleaned the egr and blanked it off no lights (I disconnected the battery for 30+ mins ) went out in it albeit only for a couple of miles and the !Removed! smoke started again !!!!
thanks in advance
mike
Hey Mike, did you get to the bottom of this problem? I've got exactly the same happening to my Avensis. I've posted already but no luck so far.
Joe
