What good MP3 connectivity based car stereo do you recommend for Toyota Auris and where is it cheap to buy/install?
caruser
Hi all,
I would not like to spend more than £70 on buying and fitting things ideally, and was looking for suggestions from you :)
My car spec is under my name.
If you have the standard stereo, then there are many options. There is a CD changer port at the rear of the head unit. This is where you plug the MP3/SD/USB adapter.
Look at the following post:
Here are links to models
http://www.ebay.co.uk/itm/Car-USB-SD-AUX-MP3-Player-CD-changer-adapter-Toyota-Auris-Corolla-Yaris-2006-12-/121474706644?hash=item1c4874ecd4:g:lFYAAOSwcu5UUnGv&clk_rvr_id=1022280352729&afsrc=1&rmvSB=true
http://www.ebay.co.uk/itm/Toyota-AURIS-MP3-SD-USB-CD-AUX-Input-Audio-Adapter-Digital-CD-Changer-Module-/141867849410?hash=item2107fb96c2:g:qdIAAOSwYIhWiVAY&clk_rvr_id=1022282646453&afsrc=1&rmvSB=true
http://www.xcarlink.co.uk/product.php?productid=35&cat=11&page=1
To remove the head unit on the Auris there are Youtube videos:
Be aware that some Nav models are not compatible according to more major brands like Yatour -   http://www.ycarlink.com/pd_10512_USB-Car-Stereo-Adapter-MP3-AUX-Bluetooth-interface-CD-Changer-for-Toyota-Lexus-Scion-Small-6-6-plug-2003-2013.htm
The La Power unit I use has bluetooth built in, at extra cost so I can also play A2DP from any device like iPhone and all Android phones. It does not support iPhone via USB. I use memory sticks up to 32gb. The unit only show track and folder numbers, not artist and song names! Some other brands do support iPhone and display track names. I am not bothered because my attention is on the driving and not distracted looking at the display.
