Help with part numbers
frankie406
Hi I recently got parts for my 2010 auris 1.33vvti facelift model the part numbers don't match up with toyodiy list.
S. Plugs 90919-01253
Air filter 17801-0D060
Cabin filter 87139-YZZ16
Oil filter 04152-YZZA7
Can someone please let me know if these are for the right car as stated above. The parts guy was in a real rush under pressure.
Air filter 17801-0D060 Good part
Oil filter 04152-YZZA7 Good part was 04152-40060
S. Plugs 90919-01253 Good part
Cabin filter 87139-YZZ16 Good part was 87139-02020
Your Parts person was spot on all the part are correct the only thing I can see/add is :
Sump plug washer 90080-43037
And ensure you use a good quality 0w20 engine oil as recommended for your 1.33 optimal drive engine.
Ah cheers Dev! Got a bit worried there nothing had went right ordering brake pads and I thought this was wrong too.ive the sump washer taped on filter box but the oil is 5/30
5w30 is an acceptable grade but 0w20 is the correct/preferred grade that your engine was designed to use.
No problem I'll keep the 5/30 for the 06 avensis d4d.and buy 0/20 thanks again Dev! 👍
