Loose ODB Port?
Mark_P
Hi all,
Does anyone have anything connected to their ODB port and is your port loose?  My ODB port is loose and for some reason I cannot keep Torque connected to the ODB device due to it being loose.
Is it possible to tighten the port?
Thanks,
Mark
Edited by Mark_P
Fixed title
I've got a little elm327 adapter connected and although the port is a bit wobbly the adapter stays connected fine because it's a tight fit onto the port. Maybe a different adapter would fit better, or an extension lead and you could relocate the adapter.?
I've had my Scan Gauge connect for ages now without any problems.
