stearing wheel pump
nikosGR45
a few days ago i learned the hard way that
stearing wheel fluid needs change from time to time and most important the filter inside the canister  must be cleaned of even better changed,
the owner manual says only "check  and add fluid if needed",
i guess is better  seling a new pump every 150000 km than oil change + filter for 30$
