Check Engine Light, TRC, VSC Lights on
superj
Hope you can help me. Yesterday, all of a sudden, the three lights came on and the car went into xxx. Max speed was 50mph (and it was heavily raining and in the middle of the night).
Had the OBDII codes read out:
p2002 particulate trap efficiency below threshold (bank 1)
c1201 engine control system
c1300 abs ecu malfunction
Any suggestions?
PS: Avensis 2007 D-4D 93kW, Diesel
Your diesel particulate filter has blocked and will require a forced regeneration to clear and then diagnosis as to why is became clogged, the other codes are set because of P2002.
