2004 1.6 windscreen washers
Victor78
Hello all
I bought 2004 1.6 petrol avensis and it's my 1st Toyota ever ..so far it's a fairly good car ..clean in general and in good condition , the only problem is windscreen washers not working although the headlights washers are fully functional  (is it the same pump for both?) So..Is there any hints or tips where I can start ?
I searched the fourm but couldn't find similar topic so sorry if reposted ..thanks :)
Have you checked the washer piping on the underside of the bonnet - may be a non-return valve (y-piece or similar) in the piping, which may be blocked or u/s.
The hose on the pump may have come off. The pumps are behind the front bumper on the offside/right.
Run the pump for several seconds and you might find a small pool of water on the ground just there.
Thanks guys for reply  ..I'll check like you people said and then I'll post back what was wrong
