Toyota Auris 2013 Vehicle Settings - Help
Hoceima
Hi All,
I have a quick query, when selecting the vehicle settings on my Auris (Not Hybrid) there is nothing there, it is blank? ..... Is this meant to be like this?
Reason I am asking because I wanted to set up features like operating windows using my key fob, or am i wrong can you not do this with the Auris? Any help would be appreciated.
Thanks in Advance.
Have you checked your owners manual that should come with the car?
https://www.toyota.co.uk/tme#/my-toyota/eManual
https://myportalcontent.toyota-europe.com/Manuals/Toyota/UK+AURIS_UK+AURIS_HV_EE_12F76E.pdf
Toyota have not implemented the window up function like Vauxhall, for closing the windows when locking the car. With Toyota's, (even going back to my old Mk1 Avensis) the power windows stop working 45 seconds after the ignition is turned off, and/or if a door is opened. Windows have to be closed or open with the key in ignition position.
I have checked the manual, could not find anything. Thanks for your response :)
  • 4 years later...
I have the same problem.  Could anyone help? Thanks
Global window opening/closing is not available on the Auris.
@FROSTYBALLS Sorry but what does the window opening/closing mean in this? I am confused. Many thanks
Another term for the feature you're looking for.
  • 2 years later...
Hi, i got ( settings not available) in my Toyota Auris 2016 hybrid.
How can i removed.
