Avensis Verso - is it an import or uk model?
ellie2761
I don't know whether my 2005 Avensis verso T-spirit 2.0 D4D is a UK or import model, I have tried to work it out by the VIN number, but the charts online don't seem to relate to mine (US description I think) but I did find a UK one that appeared to be the same as the US explanation. Both state that position 10 should be the year, therefore 5 should be 2005 but my vin number position 10 is a zero. My car has two sunroofs (or do they call the other one a moonroof?) I owned a 2002 verso before this one and my current one is more modern. I've tried looking at other similar aged verso's and they don't look much different some appear not to have a sunroof at all. I need some brake cables for it but so far the ones that my garage has ordered are the wrong ones. If I use an online part finder using my reg number the cables returned are for a left hand drive car.
Can anyone help? Thanks.
Unlike the Avensis, which was built in the UK, the Avensis Verso was built in Japan. Sold under the Avensis Verso name in Europe, it was also sold as the Ipsum in Japan and the Picnic in some markets.
PM your chassis number and I can the info you're asking for.
Your car is a Japanese built car for UK market, so not a grey import and you need Toyota part numbers:
46420-44051 RH
46430-44051 LH
46420-44051 RH
46430-44051 LH
