Clutch Pedal
Dandy63
Hi all, lately i have noticed that sometimes after i change gear the actual clutch pedal will not travel back up...i basically have to put my foot under the pedal to lift it back. Doesn't happen all the time tho....everything works perfectly well with regards to engaging/dis-engaging gears.....fluid reservoir is fine.
Any ideas greatly appreciated
