Help/guidance changing the door on a gen 7?
acme15
Hi guys,
I have an '06 GT (UK, 2ZZ with the silly body kit) which has a passenger door full of dents and pug and so on, which has also been badly re-sprayed, so I have a straight replacement door.
The replacement door is just the bare door with the wires, no window mechanism installed or anything.
Is anyone able to give me a quick guide (or a link to a guide ) on how to swap out the door, and transplant everything from the old one (window mechanism, lock, electronics, etc) into the new one..? Will I encounter any issues with aligning it an so on?
Alternatively, does the outer skin detatch/am I able to just change the skin?
Thanks! :)
Alternatively, could someone direct me to a Toyota forum with active members..? :laugh:
Hey Acme
I can't say I've ever replaced a door so can't guide you but maybe these two official Toyota workshop manuals I have will be of use to you.
I'm sure it's in there somewhere.
Hope this helps!
2000-2005_toyota_celica_repair_manual_volume1.pdf
2000-2005_toyota_celica_repair_manual_volume2.pdf
