turn off multimedia or nav screen
786s13
Hi guy,
Recently brought the new 2016 Rav4 hybrid with Nav.
I cant figure out how to turn it off. There is no DISP button where i can select screen off. None of the options within the menus allow this (from what i can see). Holding the power button just restarts the screen.
Help please.
Thanks..
Presumably your profile needs changing from the Mini One.
updated... :smile:
If you are looking to just turn off the Audio then press/release the volume button " Audio off " will appear on the screen, the screen cannot be switched off beyond that.
well i finally found a way and i was being blind..... Doh!
click on the setup tab, select display, 2nd option down says "screen off". press that and the screen goes off. :biggrin:
whenever you change radio stations or volume etc it pops up on the blank screen and you can use the central small screen in between the speedo clusters to see nav, media, hybrid mode etc away.
job done!
