X Car Link - Bluetooth Hansdfree Smartphone Calling and Music Stream post 2003 Toyota interface
martin carpenter
I have for sale an X-Car Link that magically transforms your CD player for post 2003 Toyota's (Type 1 Interface)
Selling due to disposal of RAV4 - only used for 2 weeks.
http://www.xcarlink.co.uk/product.php?productid=313&cat=11&page=1
Retail price is £129.95 - will accept £80 plus postage; also included is the bracket normally sold at
Quality is very good, uses latest bluetooth 4 technology. Also has a USB port for charging devices.
martin@thecarpies.com
The new Xcarlink bluetooth Interface enables you to stream music from any smartphone, mobile device or tablet to your original factory fitted car radio/navigation system, while at the same time providing you with a bluetooth handsfree solution. One of the major benefits of the Xcarlink Bluetooth interface is that it also incorporates AVRCP technology which also allows you to control your music via your radio or steering wheel controls.
It is compatible with all popular mobile devices and Smartphones including Android, Windows mobile, Apple OS, Blackberry etc and is ready to use as soon as you enter your vehicle - no need to connect any cables to your device (except if charging is required ).
Features
  • Connect any Smartphone including Android, Apple, Windows and Blackberry and stream music wirelessly with to your original factory fitted car radio/navigation system.
  • Control your music using your radio or steering wheel buttons i.e. Change track, fast forward, rewind, volume etc.
  • Direct CD changer port connection involving no FM Modulation for high quality sound without interference.
  • Plug and play installation - retains original equipment with the interface hidden away from view.
  • Provides a Bluetooth hands free phone solution (pauses music when calls are made and received and automatically resumes music when a call is ended)
  • Answer/Reject calls though your original car radio/navigation system via the FF (Fast forward) button.
  • Supports music streaming via A2DP Bluetooth and control via AVRCP.
  • USB charging port to keep your device charged when used with an optional USB charging cable.
  • Automatic pause when switching to CD/TAPE/FM etc.
  • 3.5mm AUX input for connecting non Bluetooth devices.
  • Works with apps such as Spotify, Google Play etc including control.
  • Separate Microphone for Handsfree included
  • Interface Dimensions: 6.5 x 6.2cm x 2.3cm
  • Continue to use your existing CD changer
Xcarlink-Bluetooth-Connection-Diagram.jp
Installation
The interface connects to the CD changer port located on the back of your car stereo. On some cars, this can be reached from the passenger side whilst on others you will need to remove the radio. Instructions how to remove your radio to access the CD changer port can be found through many online resources, car manuals or by a local installer.
Compatibility
The interface is compatible with any Bluetooth enabled device including Andriod, Blackberry, Windows, iOS mobile phones and tablets.
Compatible only with Toyota radios with the Type 1 CD changer port, from 2003 onwards as shown below.
Type 1 interface is compatible with but not limited to the following Toyota radios:
W53824, W53900, W53901, W53902, W53905, W58810, W58812, W58814, W58816, W58818, W58824 & W58826
Please note:
Toyota Yaris with factory fitted TomTom navigation system is not compatible.
Optional Accessories
3.5mm AUX cable - The AUX cable allows you to connect any audio device to the Xcarlink such as an MP3 player, iPod shuffle, Satnav Audio out etc. Ideal for connecting Non-Bluetooth enabled devices.
Micro USB charging cable - Charge any device which that has a standard Micro USB charging port such as Samsung Galaxy, Blackberry, HTC etc.
iPod/iPhone 30 pin to USB cable - Charge any Apple device with the 30 pin dock connection
iPod/iPhone 8 pin (lighting) to USB cableFor charging  of newer Apple devices with the 8 pin (lightning) dock connection. i.e. iPhone 5/5S/5C, Touch 5G, iPad 4, iPad Air etc.
Package includes
  • Xcarlink Bluetooth interface
  • Microphone
  • CD changer connection
  • User guide
