Oil filter
dankernow
What type of oil filter is on the 1.6 valvematic2011 please.
It's a paper filter, unfortunately on the valvematic, this filter is now situated horizontally as opposed to the earlier vvti engines, you will need a filter spanner to remove it, apart from that the engine is a cracker.
Thanks for the quick response. Very helpful thanks
Regarding the oil filter tool, see this link:
I also got the correct recommended grade of oil - 0w-20. I source mine from Euro car Parts and used a discount code for even more money off - http://www.eurocarparts.com/ecp/p/car-accessories/engine-oils-and-car-fluids/engineoils/5W20-engine-oil/?521776261&0&cc5_991
I did get the oil filter from them too. Here are a couple of videos
Even though these are different cars the engines and the technique are the same. The Avensis has a trap door in the under shield to access the oil sump plug and filter, like the Prius video. The Auris may be similar
The hard bit is buying the stuff.
