just the other day i went for a run with my car. I was running it pretty hard. I drove for about 20-30 min. After awhile the car started bucking as if it want to close off. I stoped the car and turned it off when i started it again ..it was running good , then it started to do the same thing. i nearly made it over a hill it sounds as if it was missing out (not sure). and it kept bucking. There was a great lost of Power
Can anyone give me any ideas as to whats causing this problem.
I changed the plug wires baught new ones and checked the plugs but they seemed ok. Also the Coil wire.
It doesn't happen when the car is cold when i run it for about 30min hard it happends
i asked a mechanic he was telling me that the Turbo carries a log it's not to worry about? that kind of thing happens????? :blink:
Is that so??? <_<
