1988 hilux front wheel play/movement
jackboil
my 1988 LN106 hilux failed its warrant due to front wheel play.
the play was up and down on the wheel.
i thought it was wheel bearing play so i repacked them and properly adjusted the wheel bearing 54mm bolts.
there is no play when i move the brake rotor so it shouldnt be a bearing problem but there is still a bit of up and down play through the front swivel hub.
Any ideas what could be causing this?
Cheers
