Exhaust Gasket Help PLEASE
Kmac888
Hi everyone,
My wife's cars is a 2002 Yaris 1.3 automatic 5 door (think it's Japanese made not French)
It's time to change the exhaust (middle and back box) I've found the exhaust on eBay but I can't find which gaskets/clamps I will need.  Can anyone help..........?
thank you
Welcome to Toyota Owners Club.
Topic moved to the Yaris club.
Assuming the part you purchased is an OE style part and not a cut and shut then the picture shows you the original part setup where the joining ends of the front & rear sections have a flange with gasket between and all pulled together with a covering clamp
hi thanks for the reply........no it's not an OE part its from eBay middle and back box section
from your diagram it looks like I need number 17451 (donut shaped metal ring) which I have found at euro - see below
(eurocarparts - Autogem Exhaust Gasket/SealProduct Code: 374680011)
also number 90119-08Bo2 (bolt) and 90461-15013 (ring) which i can't find......hopefully I can re-use the old ones???
thanks
Just go to your local dealer and buy the bolts and ring, the bolts are a few quid and the ring is £15 plus VAT, or I can mail order them to you (plus carriage charge)
Kingo
