Bottom cover D4D 85KW Toyota Avensis 2005 damaged
kinurabi
Is there any way I can find used bottom plastic cover of the timing belt for a Toyota Avensis 2005 D4D 2.0, 85KW model?
I had a timing belt failure so I suppose that was the reason the cover got damaged
http://www.japan-parts.eu/toyota/eu/2004/avensis/cdt250r-almeyw/3_273550_083_223W/tool-engine-fuel/1106_timing-gear-cover-rear-end-plate#11385
