MM-T Valvoline Change
Carguys
Can anyone tell me if i can change the gearbox oil in a mm-t gearbox?
Yes, its a standard type manual gearbox with an automatic actuator to control the clutch
I would say yes. Unless it has CVT. It is supposed to be a manual gearbox with with automated device that changes the gears and operates the clutch.
If you have the handbook, you will find the fluid capacity and grade.
thanks a lot!
no its a mmt gearbox
If the gearbox follows Toyota typical design, the drain plug is below the left driveshaft, whilst the filler is on the front face of the gearbox. The socket for both usually is 24mm.
I did this job on my old Avensis on my raised drive, which also gives access to the change engine oil without having to use ramps or axle stands.
