Celica service schedule mk7 140 2002
Jbond87
Does anyone have a Celica service schedule for a mk7 140 2002?
Thanks,
What exactly would you like to know?.
  • 4 weeks later...
Well my car is currently at 100,000 miles and it was last serviced at 83,000 (before I bought it) so I would like to see what needs doing to keep it on track for full service history.
Thanks,
In your case, every odd year it's due an interim service, which is basically oil, oil filter, and visual check over.
Every even year it's due a full service, and if you plan on keeping the car for some time to come, I'd recommend the following..
Oil
Oil Filter
Air Filter
Spark Plugs
Toyota LongLife Coolant (if still on original radiator, order a replacement from eBay at the same time)
DOT4 Brake Fluid
75W90 Gearbox Oil
Air Con re-gas
The front and rear calipers should also be stripped, cleaned and greased.
None of the parts above are expensive (with the possible exception of the Toyota LongLife coolant), with EuroCarParts/CarParts4Less always competitive on pricing.
HTH :smile:
