Carina Door Trim
jim1933
I need to stick a Door protector trim back, it has lifted on the end, dont know why can anyone help with suggesting a glue that will do the job please, thanks Jim :thumbsup:
For glueing trim against bodywork panels I would use a two part epoxy adhesive such a areldite. Be sure that you can get sufficient between the trim and the bodywork without having to distort the trim too much - ladeling the mixture into a syringe might do the trick. Also you will need to devise some method of clamping the bits together whilst drying to improve the end result.
Hi gazza1286, Thanks for the advice -I am going to try that tommorow, :thumbsup:
Thanks gazza1286. I did the job with Araldite and it looks like it has fixed them ok. Many thanks :thumbsup:
