For technically inclined. Cruise control for auris 2016
gpa
Hello people,
It used to be a common secret that in certain auris models, we could install afterwards Cruise control without problems,
Does anyone know if that can be applied to auris active 1.2 turbo too? Manufacturers schema for the two cars ( active - style) seems indentical, and i dont think that the ecm and the panel instruments have different part codes. So that means we can easily install cruise control to active level.
Can anyone enlighten me?
Cheers
The cruise control installation guide found here:
At the bottom of his post it says that the cruise control will not work if your car has the 4ZZ_FE Engine which I think is the 1.4 version of the Auris.
Recently fitted it to my 2.0 using this guide and had no issues.
