Courtesy Light Drver's Side Door Switch
the_hood
Hi, I'm looking to replace the driver's side door switch. I just wanted to ask if this is a simple unscrew the old on and screw in the new one job. Also, is the part unique to the Auris or shared with other Toyotas? Thanks.
It's a simple unscrew, the switch is common with other Toyotas (connector is the same), you can buy another one from scrap yard, from a RAV4 for instance...
