How many KM/s till every cvt oil change on 1.33cc Toyota IQ 2011
Charis IQ3
Does anyone know at how many kms i must change the gearbox oil for my toyota iq cvt?
I don't know about the Toyota iQ but I have the Auris 1.6 CVT and, so far as I can determine, there's no specified oil change period called out. It's a case of the box is filled at the factory and is only checked for external leaks during servicing. It's even quite a long drawn out procedure, using special equipment to even check the oil level.
You might be interested to read this though
http://www.pakwheels.com/forums/d-i-y-projects/168298-transmission-oil-change-toyota-vitz-belta-passo-k410-transmission
Following on from Tom's post. The only reference to the c.v.t. in my Yaris (1.33, c.v.t. multidrive) service book is under additional inspections, no mention of replace fluid, every 40000 miles/4years.
