I'm in for the LONG HAUL... :<)
All sounds positive, looking forward to your report 😄
Well.... Nice n Brite!!   😵
I haven't done the treeless Wooler route 'testing' quite yet*
*nor likely 😕
Better than what came out [of the front, in darkness]...
5*****
2sav
Just been rummaging through junk boxes on Amazon.... Looking for bits for the 4A-F.
Scored lucky with a set of moulded Bosch 7mm leads @£10 😉
Blueprint Rotor arm and Intermotor Cap.
Although Toyota have a good rep on quality, and the car has only done 90k, I think all new parts + carb tune will be a good move
2sav
Oh that's a good find, well done 😄
Even better.. !!
The leads have turned up [in a disconcertingly humongous box] only to fall out with a Dizz cap included...
I will return the loose cap I ordered for full refund.
WTG Amazon 😀
2sav
That's good going 😄 bonus time lol..
I have a fairly broad selection of combi spanners...
Mostly noname and rough forge stamped 🙁
In TK Max, of all places, I spied some svelt, highly polished spanners. Not [sadly] in their very large 'clearance' tub but reasonably priced.
#66092
£12
Loverly 🤓
2sav
Whilst in the mood for spending money....
... I sourced 2M of Red silicone vac hose [4mm i/d] so that all vac leak worries will be cleared up before I start tuning. £3 Amazon 😉
2sav
Sounds like you've gotten some great deals 😄
Woot Woot....
Red hose plopped thru letterbox just now
We Are ON 🎱
2sav
Sounds good, looking forward to the update.
Bit of an update on the Cambox gasket (with a good splodge of BlooHylomar!) + 4 new plugtube 'polo mints'.
No oil leakage = oil on top notch & clean as Mazola
2sav.     😁
...... my neighbour 'parking by braille™' again  ¥π÷∆¶¢$¥€ !!! 😵
2sav
Good news on the cam cover gasket, not so good news on the rear bumper 😞
  • Sad 1
I'm going for a ..... Bit'o Bling!
Stainless, no less... Replacing the 2 acorn nut (plus a random rusty nut) on the Cambox Cover.
I need cheering up
2sav
That's the spirit 😄
Just popped for a wiper/turn cluster, on eBay, to lash up a fix to the 'Right Turn Signal' cluster contacts... Attempting to indicate Right has the cowling emit a sound not unlike stick-welding!!
When you put the indicator/lights arm forward [full beam] the winker flashes great = No Wear on the pips. I need to strip down the switch and replace (from the spare) a fresh/little used pip contact.
Later models have a 'modular' design, with the swich assembly is simply a plug-in c/w arm.
Mine (and similar age MR2) have a complete alloy do-nut going around the wheel... So its a strip n scratch about fix....
I forgive it after 27yr 😬
2sav
Well well well....
Nothing new in the World....
We have [to quote Blackadder] "A Plan"....
2sav
Looks interesting 😄
I'm not sure I have a 19mm socket in my box... So bought one for £2 off Amazon. Should arrive around the same time as the Stalk assy.
Not at home atm so can't look....
2sav
My MR2 switch assy arrived today.... And my 19MM socket.... And my Wingnuts 😁
I'm clearing a space to strip it down (carefully) to see what is what with the 'winker' contacts... What these s/hand ones look like and how, hopefully, I might fix/swap 'in-situ' my faulty ones.
Like a nice mystery, me.... Bring It On!
2sav
Winkers Sorted **Winnah** 🎱
..... the bit of tinplated brass that slides across the pips was 'worn bright' = should have a matte tinning finish.
The piece from eBay, my MR2 switch slider is mint... So just swapped over and I 'lightly scuffed' the surface of the pips with the edge of my jewellers screwdriver. Re-smeared everything with the excess/clean grease from under the cover and clipped everything back in place.
.... sharpie pen mark to keep wheel back in correct spot!
The nut was finger tight - likely years of folks heaving out.. Fitters arm crank retighten! NaaPraablem 😉
2sav
Very nice, and I do like the dash layout 😄
Posted (edited)
98,000 dead today. 👍
2sav
Edited by tooSavvy
That's good going 😄
