Shudders when pulling away?
thom1983
Hi guys, noticed a shudder sometimes when pulling away in 1st? Is this a clutch problem?
Sent from my iPhone using Tapatalk
Could be a small amount of oil leaking on it that then burns off. do you sometimes catch a whiff of burning when you pull away
No smell of oil and it's only in 1st, sometimes it's fine. Apparently it'd had a new clutch before I bought it
when they replaced the clutch did they also replace the DMF?
I don't know, was done before I bought it [emoji52]
Scott, Thom's car is the petrol vvti so should not have a DMF. So long as all the parts have been changed, then it would be down to the quality of the parts and how clean. Did the old clutch wear down to the point of damaging the flywheel?
I hope it is just the old dust and the clutch needs bedding in. If there is paperwork /receipt of the work done, Take it back to who did the work if possible.
Aye it doesn't seem as bad so let's hope that's the case
