Cd player fault codes
Long Jon
My cd player will not accept a disk and comes up with fault code 1. Help!!
Seems to be either a problem with the CD (dirty, damaged, etc) or an internal issue with the player. Some have tried a lens cleaner with limited success - though Toyota usually recommend not to use these.
Have you tried disconnecting the Battery for a few minutes?
I had to do this when my verso DVD player failed to eject the disc, worth a try and can't do any harm.
Sent from my iPhone using Tapatalk
I will try disconnecting the Battery once I have found the radio code.
Watch this space!
