Help with Toyata Yaris 2005 1.4 Diesel P1520 Error Code
YayYaris
Hey Guys
Recently brought a 2005 Yaris T-Spirit 1.4 Deisel with 74,000 on clock. It's my first car and suffice to say I'm well excited.
That being said I've done a full service (had prior mechanical experience) and I've made sure everything should be shipshape.
  • New fuel filter (blueprint)
  • New air filter (blueprint)
  • New Oil filter (you guessed it, blueprint)
  • 540 Fully Synthetic Oil
  • Removed EGR valve, cleaned it.
Although I've been having trouble with the an error code P1520.
I detected the code using a bluetooth OBD scanner and I cleared it but it still returns. I've had no luck googling and I was wondering whether any of you guys could help?
P1520 Stop Light Switch Circuit Malfunction
DTC No. DTC Detection Conditions Trouble Areas
P1520
Conditions (a), (b) and (c) continue for 5.0 seconds or more:
(a) Ignition switch on (IG)
(b) Brake pedal depressed
(c) STP signal OFF when ST1 signal OFF
(The MIL is illuminated and a DTC is set when the same malfunction is detected on 2 consecutive trips*
*: One trip is counted when the ignition switch is turned from off to on (IG) and back to off)
  • Short in stop light switch signal circuit
  • Stop light switch
  • ECM
