Just received a new exhaust plus fitting kit, including new rubber mounts and clamp, for the missus' 2006 Sport. Sodding bracket on exhaust came off, otherwise it was still in good nick :angry:
Does anyone with experience on this, know if I need to use some kind of exhaust mounting paste on the joint, and if yes, can you recommend a product please?
from Halfords or a motor factor you will be able to get some exhaust assembly paste
you dont have to use it but it will give you a gas tight seal on each connection
Just a heads up for anyone who fancies fitting a replacement rear silencer themselves.
Did mine this morning. Took around 45 minutes to complete. That included jacking up the driver's side for better access to the exhaust. I gave the clamp a good squirt of PlusGas Formula 'A' the previous night, which made removing the rusty bolt a doddle. Highly recommended stuff!
The end where it joins to the middle section, actually slides into the pipe for a couple of inches until it joins the mating surface. Then the clamp squeezes the two ends together. Due to this design, I felt it was unnecessary to use any assembly paste.
I bought my exhaust from eBay. The quality of the product is very high, and the clamp supplied in the fitting kit is actually beefier than the original. Link below:
Exhaust Rear Silencer TOYOTA AYGO 1.0 Hatchback back box since 2005 mounting kit
For 35 quid, that's certainly the least amount I've ever paid for replacing a rear silencer on any car I've owned :smile:
  • 4 weeks later...
OMG, I've just had to buy another one of these, coz my 13 plate on 25k is starting to sound a bit too sporty lol. BTW, the other one was for the wife's car.
I know it's down to the baffles rotting from the inside due to low mileage journeys, but the original Toyota exhausts really are made of cheese :blink:
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
