Rubbing Noise / Low grinding / scraping noise
celicability
This noise is only evident after about 30 miles continued driving like motorway but then dont go away till everything cools down again
Sounds like something at rear is scraping / binding / squeaking
Had car on ramp / both rear wheels turn good without any noise or stiffness
Could it be parking brake related / something not releasing etc / handbrake works fine
Around town / low mileage journeys noise never appears
Mot shows advisory rear brake fluctuating but not excessively off side if that helps
Any help appreciated ?
slightly bent out the stone guard behind rear offside brake drum which was rusty hoping it was that scrapping when it got hot / keep you posted either way if it works or not
