Buying Rav 4 advice please
Dannyh9
Hi all,
im in the market for a 2006ish Rav 4 to be used with the family and towing our light 4 berth caravan. Ideally I'm looking for the updated 2006 model 2.2 diesel. There are a few listed on auto trader etc..
Is there anything I should particularly look out for when test driving/inspecting the vehicles? Also I would expect the mileage on the car will be between 70000 and 100000. Is there anything you would have expected to have been replaced by that point eg clutch, timing belt etc..
many thanks and hopefully I will be a fully fledged Rav owner soon!
Danny
One needs to be aware of the possible head gasket/oil consumption issues that affected what is thought to be a small percentage of the 2AD (2.2 litre) engines - see
A Toyota dealer should be able to confirm whether a replacement, modified engine has been fitted. Otherwise a 2006 Rav4 will be outside of the 7 year/111,846 mile goodwill arrangement Toyota adopted to assist owners with affected engines.
Thank you. Great help. Does the 2.0 have the same issue?
From thread I linked to, you will see that details the 1AD (2.0 litre) fitted to the Avensis and Auris were also affected.
