Parasitic battery drain
frankie406
Hi I've found the route of my problem with my Battery drainage over a couple of days.I bought a new Battery and checked for the drain.I found it in the engine compartment fuse box (fuse 21 DCC 30A :"ECU-B 2" "DOME" & RAD NO.2" can anyone point me in the right direction to this or has wiring diagram of these?
I'd guess dome to be the interior light, and rad 2 to be a permanently live feed to the radio.
Cheers Alan. Found the fuse under the steering wheel fuse box.it was a 7.5A fuse took it out load dropped off to 0.01
Put it in and jumped up again.cleaned the fuse and had stayed down.i'll keep an eye on it to make sure.
