2012 avensis 2.0 d4d 2012 gear oil change
Andyv
Need to change my gear oil so can anyone tell me where the gearbox oil filling point is and how much do i need?
Sent from my iPhone using Tapatalk
Your Gearbox oil is designed to last for the vehicle life without change only needing the levels checked every 40,000/4 years if you really want to replace you will need:
2.3lt  API GL-4 SAE 75W
A003E2JE01
Text in Illustration
*1 Filler Plug
*2 Drain Plug
