Need Toyota Yaris 2003 tail or backlight wiring schematic
Martintim
I have just installed my new tow bar and I need the backlight wiring schematic/diagram.
Of cource I could find the correct wiring by testing each connection but some of you might have the backlight wiring schematic for Toyota Yaris 2003 so I 'am just going to ask if there are some here who has it ?
I fixed it myself, so here are the tow hatch wiring for Toyota Yaris 2003. Hope this helps someone others:
Left Side plugg
Lights
Vehicle Wire Colours
Alternative
Notes
Pin 1
LH Flasher
Green / w. black  stripe
Light green
OK
Pin 2
Brake Light
Green /w. white  stripe
Light brown
Pin 3
Ground
Yellow / w. black  stripe
Pin 4
Pin 5
LH Side Light
Green
Pin 6
Fog Light
Red / w. black stripe
Blue
Pin 7
Right Side plugg
Lights
Alternative
Notes
Pin 1
Reverse lamp
Red/w. white stripe
Pin 2
Pin 3
Brake Light
Green/ w. white  stripe
Light brown
Pin 4
Pin 5
Ground
Yellow/ w. black  stripe
Pin 6
RH Side Light
Green
Grey
Pin 7
RH Flasher
Green/ w. yellow  stripe
Yellow
Ground pin 3 for left tail lights and Ground pin 5 for right tail light is not necessary to use when you are using car chassis for ground.
