Cat cleaner?
Faz778
Hi Folks.
I have a 2003 1.8vvti Avensis. Toyota kindly replaced the short block at 75k miles due to the oil burning issue and I'm very chuffed about that. However, since then my engine management light has been on constantly. My mechanic checked this is out and says it's due to a mis-match in the oxygen sensors before and after the cat, probably caused by a dirty cat caused by the burning oil. The car still passes its emmission checks so I haven't bothered changing the cat.
Is there a decent cat cleaner out there which I could try in order to get rid of the annoying warning light?
Try cat-a-clean.search for it online
