OBD
nico1135
Hi sir,please I have 2003 toyota  avens averso....sometimes this OBD signal show up on dashboard. Can you tell me what's wrong with my car.thanks
The OBD light means your On Board Diagnostis system has detected a fault you will need to connect the car to a compatible diagnostic computer and have the fault code read then diagnosed
Obd signal? Do you mean the engine management light? It could be a host of things you would be better to get it plugged into a diagnostic tool and see what the problem is.
Yes.Ok  I will try and check  thanks. Ok
