EGR valve TR D-4D 2008
DinglediggerJ
EGR valve, after-market replacement TR D-4D 2008. Where can I get a replacement EGR valve for my 2008 AVENSIS TR D-4D? Is it really only available as a Toyota official part and costing almost as much as the car is worth? Any suggestions from anyone gratefully received. I have had the valve cleaned once a year ago and the 'limp home mode' occurs every few months and then disappears. Thank you for any suggestions. Jeff
Hi Jeff,which engine (1AD, 2AD-FTV or 2AD-FHV)?
I know that Opie Oils sells Denso EGR valves. Also the first result on Google was this http://www.ebay.co.uk/itm/Genuine-Toyata-Avensis-EGR-Valve-25630-26020-/351641621892?_trksid=p2141725.m3641.l6368
If you have had the valve cleaned before did they also clean the manifold? Perhaps worth doing again?
Hi Scott. Not sure how to tell which engine but the log book says:
Version: ADT251(LT)
Variant:ADT251R-ALFEYW(1J) - does this give a clue?
The valve seat might be sticking open/closed.did you clean the egr and exercise the valve for operation manually or electrically?
Version: ADT251(LT)
I think that makes it a 2AD-FTV. Is it a 150bhp 2.2?
try www.eurocarparts.com before you checkout use holiday30 (30% off) or payday20(20%)
