hi just wandering does anyone know where to get front Speakers for my corolla as in the original ones as mine blew
Are you wanting to replace with the same toyota Speakers, if so then look in the for sale forum or put and ad in the wanted, someone who has done an upgrade might still have there old ones, threw mine away after keeping them for 3 years.
http://www.toyotaownersclub.com/forums/forum/23-for-sale/
You can get a  much better sound by fitting same size aftermarket ones, a vast choice, not to difficult to replace either.
Plenty at places like this one, you get what you pays for.
https://www.caraudiocentre.co.uk/category_m-car-speakers_c-2738.htm
Wonder what blew your old Speakers ?  will the new ones be ok ?
If you think your head unit might be blown then the same thing applies as with the Speakers , as many folk remove the original unit for an more modern aftermarket one.
i was going to use aftermarket Speakers but dont you have to re drill all new holes on to fit them where as the original ones just plug straight in?
I had to drill the old ones out as mine were riveted in; the new ones fitted into the same holes with some extra wide washers.
Think most same size Speakers have the same 4 holes / universal holes to avoid such problems, but you ought to double check on their exact size / specification with whoever you buy from.
