Just been fitting the cylinder head on my 3zzfe and had a problem when fitting the bolts. 3 out of the 10 bolts wouldnt go right down when hand tightening the bolts as the holes had some old oil in them. I managed to extract some oil by putting the bolt in as far as it would go without resistance, taking it out and wiping the excess off with a tissue. I repeated this about 10 times intil the bolt went in without resistance and did the others for good measure. I tourqed the head down no problems, i am just worried about the excess oil in the bolt hole and whether it would cause any problems long term?
